Ref: Console Hacking 2016 (33c3) - YouTube
I came across this video, in which, the presenter describes the PS3 architecture.
He mentions that the south bridge on a PS3 is not a dumb controller, but a full blown ARM SOC which is used for background tasks like updates etc.
From what I understand, all the peripherals and storage (except main RAM and GPU) are attached to this SOC and are passed through to the main CPU.
Is something like this possible on commercial desktop systems? The use case that I visualize is as follows.
- The low power ARM SOC runs a linux system which acts as some kind of orchestrator.
- When a high performance task has to be run (like a video game or build task etc), it composes a system with the high power CPU and GPU + an emulated storage device/disk image, and boots this system.
- Peripherals are passed through from the host ARM system to the high power system for user interaction.
The advantage I see is similar to that of hybrid CPUs. ie. low power cores for everyday tasks and power hungry hardware for demanding tasks, but with the ability to completely power off the high power stuff when not needed. (something that is not possible with hybrid CPUs).
If this is not possible in commercial systems, what is the closest configuration that allows such a functionality? - a master system that creates a disk image for a secondary (more powerful) system and passes through peripherals?
