Are these the same?
Hi I've been looking around for a lower price for an asus Z97-pro motherboard and I found one that looks like it, but I'm not sure if its a different model that is lower quality, could someone confirm that the mother board is similar to each other? Theirs only twenty in stock in amazon and I would like to purchase it before their all gone.
this is the motherboard that I want
http://www.newegg.com/Product/Product.aspx?Item=N82E16813132116
and this the motherboard on amazon that is cheaper then newegg
http://www.amazon.com/ASUS-Z97--DDR3-2600-Motherboards/dp/B00K2MAU5Q/ref=sr_1_3?s=electronics&ie=UTF8&qid=1417906532&sr=1-3&keywords=ASUS+Z97-PRO+LGA+1150+Intel+Z97
No just look at the title of the motherboards, they have slightly different specs and feature sets.
here is neweggs
http://www.asus.com/Motherboards/Z97PRO/specifications/
Amazons
http://www.asus.com/Motherboards/Z97A/specifications/
Nope. The model you want is called "Asus Z97-PRO" Search for that on Amazon. The A Model and Pro Models are Different but Aesthetically they look almost identical.
The Z97-PRO and Z97-A are two different boards:
Here's the Z97-Pro:
http://www.asus.com/us/Motherboards/Z97PRO/
Here's the Z97-A:
http://www.asus.com/us/Motherboards/Z97A/
If you run the Asus comparison tool you'll see there's a few more bells and whistles on the PRO but they're base specs are very similar.  The Z97-A does have some advantages in some areas though (the PRO doesn't support quad AMD cards, where the -A does, but they both support quad nvidia.)
Thanks you guys I appreciate your feedback. I searched the z97-pro on amazon and that popped up. I thought it was a bit fishy because it didn't have the same title as the one on newegg and I didn't feel fully feel that they were the same, but the looked the same and I couldn't seem much detail about the motherboard on amazon like newegg, thanks again you guys!
