Are these specs good and will it work?
Hi and I'm wondering if these specs will work well with the system. So I would like to know if it'll all run or fit properly. I'm new to this stuff so I need some advice.
Thanks
My Specs:
PSU: Corsair Builder Series CX 600 Watt ATX/EPS 80 PLUS (CX600)
CPU: Intel Core i7-3770K Quad-Core Processor 3.5 GHz 8 MB Cache LGA 1155 - BX80637I73770K
GPU: ASUS HD7850-DC2T-2GD5-V2 Radeon HD7850 2GB DDR5 256bit PCIE3.0 Video Card
Motherboard: ASUS P8Z77-M LGA 1155 Intel Z77 HDMI SATA 6Gb/s USB 3.0 Micro ATX Intel Motherboard
HDD: Seagate Barracuda 500 GB HDD SATA 6 Gb/s NCQ 64MB Cache 3.5-Inch Internal Bare Drive ST500DM002
SSD: Don't really know what it does so I'll leave it
MEMORY/RAM : Kingston Technology HyperX 8 GB (2x4 GB Modules) 1600 MHz DDR3 Dual Channel Kit (PC3 12800) 240-Pin SDRAM KHX1600C9D3K2/8GX
Case: Sharkoon t28
OS: Windows 7 Home Premium
Optical drive: ASUS Internal 24X SATA Optical Drive DRW-24B3ST/BLK/G (Black)
Umm some of it is squished up so I hope you people can still read it. If you can't then I'm sorry, because I'm new to this fourm.
Make an account on pcpartpicker and then post the link. Other than that I'd recommend either go AMD or get an i5 3570k instead of the i7 and put the money you saved towards a better gpu such as a 7950 or 7970  or even maybe a gtx 670 0r 660 ti if you like nvidia more.
Budget?
umm i do not know maybe around $600-750? So maybe could you find me some cheaper specs?
That what you want is impossible with that budget...
ok then, umm give me pc specs that cost around $600-750
http://pcpartpicker.com/p/Lbxv
if you find out you do not want to buy OS you can buy 7870xt Sapphire 100354XTL
