Are these components compatible
I am Planning on building my first computer and, I am wondering if these parts are compatible with each other?
AMD FX6300 Black Edition 6 Core (CPU)
Asrock Socket AM3+ 970 Extreme4 5200MT/S (Motherboard)
Gigabyte GeForce GTX 650 2GB PCI-E DVI HDMI (graphics card)
LiteOn IHOS104 (optical drive)
Logitech Wireless Desktop MK250 (wireless keyboadr and mouse)
CiT Vantage Black Gaming PC Case with 600W PSU (case (power suply included))
TP Link TL-WDN3800 N600 Wireless Dual Band (wireless card)
Seagate ST1000DM003 3.5 inch 1TB Barracuda (hard drive)
Windows 7 home edition (OS)
Serial ATA Sata Hard Drive Data Cable Lead (spare Sata cable)
I would much appreciate it if you can help me, thanks.
What is your budget?
around £ 650 ($991.97 ish?)
http://uk.pcpartpicker.com/p/SnIb
CPU: AMD Phenom II X4 965 Black 3.4GHz Quad-Core Processor (£69.99 @ Maplin Electronics)
Motherboard: Gigabyte GA-970A-DS3 ATX AM3+ Motherboard (£50.39 @ Aria PC)
Memory: Corsair Vengeance 8GB (4 x 2GB) DDR3-1600 Memory (£55.00 @ Ebuyer)
Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive (£68.99 @ Amazon UK)
Video Card: Gigabyte Radeon HD 7870 2GB Video Card (£189.59 @ Amazon UK)
Wireless Network Adapter: Asus PCE-N10 802.11b/g/n PCI-Express x1 Wi-Fi Adapter (£14.50 @ Amazon UK)
Case: Zalman Z9 ATX Mid Tower Case (£37.61 @ CCL Computers)
Power Supply: Antec High Current Gamer 620W 80 PLUS Bronze Certified ATX12V / EPS12V PowerSupply (£61.13 @ Amazon UK)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer (£11.13 @ Amazon UK)
Operating System: Microsoft Windows 7 Home Premium SP1 (OEM) (64-bit) (£68.39 @ Aria PC)
Keyboard: Logitech K120 Wired Standard Keyboard (£14.99 @ Amazon UK)
Mouse: Logitech B100 Wired Optical Mouse (£9.99 @ Amazon UK)
Total: £651.70
Thanks for the help. Hust wondering if I could use a blu-ray player because I am planning on using it for home entertainment and productivity.
This bluray player is currently on sale for £28  http://www.amazon.co.uk/IHOS104-Internal-Including-CyberLink-Software/dp/B0079GI0OQ/ref=sr_1_1?ie=UTF8&qid=1366731618&sr=8-1&keywords=internal+blu+ray+drive
Normaly a bluray player will cost you £45+
thanks, for your help!
would i benifit from a solid state drive?
Not realy you can allways add one at a latter date
if you what to store a lot of data its just so much cheaper to use a HDD.
I use a 64gb ssd for my boot drive just to get windows running faster and thats about it as there isent a lot of space left every theng else gos on my harddrives (wich cost less than the 64gb ssd lol )
Are the sites where you buy them from safe? because i have not heard about some of them before.
Pcpartpicker only picks parts from legit sites
