I've been searching around and I can't find a M-ATX mobo to go along with a 8320. If someone could point me in the right direction or if there is a direction at all, it would be appreciated. If ther isn't one, do you know if there will be some coming out soon. If so, when?
I was only able to find 14 boards after searching for 8 seconds. I will try harder next time. http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007625%20600009017%20600138080%20600158776&IsNodeId=1&name=FX%20%2f%20Phenom%20II%20%2f%20Athlon%20II%20%2f%20Sempron%20100%20Series&ShowDeactivatedMark=False
First off, I must appologize to you, ThatGuyJohn. I was REALLY tired last night. I guess when I opened your link to the motherboards they looked like atx to me...
@gigabusterEXE, I am looking for micro atx... just that what I said above I was really tired.
So, my best bet atm is the motherboard that Phosgene recommended (which is also in one of the 14 that ThatGuyJohn linked now that I look at it). But do you guys know if any 970/980/990X/990FX micro atx motherboards will be coming out anytime soon, preferably asrock/asus?
I haven't heard or read anything that would lead me to think that but, it sure would be nice to be able to build a m-atx system that "fully" supported FX. I tried digging for one when I did my last AMD build. I think there is a marketing strategy here by not doing so though. I think AMD could be wanting people to go with an APU when doing smaller systems. I have been seriously considering building an APU system myself, just for that reason. I kind of want to see what it can do paired with a mid-range GPU in a HTPC.
well the 980G chipset is a rebranded 880G, but i doubt youll see any 970 or 990FX MATX motherboards due to the fact that the 9XX chipsets like power as do bulldozer/piledriver which is a lot on a small motherboard
