since my case has a glass side panel, I want my buld to look good. From what I read the Evo 212 is the best cpu cooler out there for my budget of $30 but i want one that looks better with the same cooling capability. Its kinda ugly to have a huge chunk of aluminum and copper sticking out my motherboard. Whats out there? my motherboard and Cpu are in the link above^
(Preferably ones with the fans facing tords the side panel)
Any advice will help!
UPDATE: thx everyone for the help im gana get the Enermax ETS-T40 CPU Cooler
At $30 probably not many could compete. Cooler Master did the smart thing and put function over form but if you need a better looking cooler see if you can raise your budget to $50 and get an Enermax or Xigmatek Dark Knight II
only a sink built for low profile systems. but then youd look like a pancake this noctua complies exactly to the Intel LGA115x socket NOT YOURS. but just as an idea to get a fan pointed towards the side panel
