Hello guys,are these pieces compatible?
1-I9-10900k
2-MPG Z490 GAMING CARBON WIFI.
3-32RAM
3-ASOUS 4070 DUAL
4-A850GF
Welcome to the forum! Long gone are the days that you need to ask forums for compatibility. Just check pcpartpicker.
Looks compatible to me. Keep in mind the 10900k comes w/o a cooler.
1 and 2 and 3(b) are compatible. 3(a), though… what kind of 32RAM? DD3? DD4? DD5?
It needs to be DD4 for the l9-1O9OOk. Is it 32RAM per ram, or is it 32RAM across 2 or 4 rams? You probably want at least 2 rams for the best speeds.
Provided that RAM is DDR4, yes, should be.
Although spending $1800 on a system from 2019 feels kinda… Whut, why? A 14900k build or a 7900X build for the same money would be a much better investment and give a much bigger speed boost.
Your choice though and fully understand if you are updating an older system or something. ![]()
[edit]This is my pick for a system that would perform about the same as yours only with modern parts. This is roughly $1350, so if you are buying used, I would not accept more than $1000 out of those parts. As always with PCPP builds, they are a starting point, not the final build.
The Intel I9-10900K CPU only supports DDR4 memory up to DDR4-2933. While more modern (=faster) sticks should support DDR4-2933 mode (but would require manual configuration in UEFI/BIOS), getting the correct modules should save money.
That 850W + 4070 combo, should have 0 issue
Z490 + Gen10? Are you trying to avoid P/E stuff / power SIPHON
32GB [2x16] shouldn’t be an issue-- Are you running XMP-OC or listed limit?
