Are AM3 CPU coolers compatible with AM3+ sockets?
I'm planning to buy a DeepCool Iceberg Pro CPU cooler, but the manufacturer's website did not state any AM3+ compatibility in the description, is it because the AM3 is just the same as the AM3+ in terms of CPU heat sink mount fitting? Or maybe the AM3+ socket isn't compatible with this kind of CPU cooler?
http://www.deepcool-us.com/product/ICEBERG_PRO/
Please leave any suggestions for a better CPU air cooler for the AMD FX 8350. My budget is around $30 to $72. Cheaper would be better.
A Merry Christmas and A Happy New Year to all you folks here at Tek Syndicate!
they should be just on the fact that u can use an am3 cpu in am am3+ slot.  I purchased a corsair h100i ($125) it says its only am3 but it works on my fx8350... i would recommend an h seriers  from corsair http://www.newegg.com/Product/Product.aspx?Item=N82E16835181032 depending on the room u have in ur case. With the h100i under full load i havent gone past 30oC
The mount for CPU coolers is since the am2 plattform the same on the amd's. am2,am2+,am3 and am3+ have the same mounting mechanism and the same dimensions. so any cooler that says am2,am2+,am3 or am3+ will fit your needs. I don't know anything about the DeepCool Iceberg Pro but I'm shure it will be better than stock ;D
