We have a simple little garden fountain kind of like this
Down here in Alabama ('Murica y'all) it gets very toasty outside in the summer. We all know what happens when water gets hot...It vaporizes! And we all know what happens when too much water vaporizes in a fountain...it burns the pump up! (definitely don't know this from experience)
The way the fountain is put together, it's pretty easy to take the middle "cylinder" and the second tier off (making it look like a birdbath for all intents and purposes) and in the middle of that is where the pump is. There's quite a bit of extra space in there, certainly enough to run small tubing (like aquarium tubing or something, not a garden hose) and be able to discreetly fill up the fountain without having to lug a water pitcher out there. There's also plenty of space to put electronics and whatever underneath the fountain, because the bottom is all hollow. There's already an electrical outlet there to power the pump, so I was wondering how hard it would be to make some kind of Arduino thing that would detect when the water is below a certain level, and then flip a valve to fill up the fountain. It doesn't need to actually pump water, there's a garden hose spigot nearby that we could use for this, I just need the arduino to control a valve (like a sprinkler system valve maybe?)
I was thinking of using a Raspberry Pi instead of an Arduino, because it would be cool to be able to automate the fountain and because that means I can hook it up to a network and maybe also have it put algae remover in there during the really nasty times...but I dunno, is there a way to hook up an arduino to ethernet and have it do basic stuff? I don't need to run a web server or anything, but if it can send data to some sort of logging mechanism that'd be great.
And of course there's the physical structure of it all. I would have to drill a small hole in the center of the fountain to run the tubing into it, and I'm not sure how I'd do that. I guess use a hole almost the size of the tubing, and put some caulk around it?
And the valve....what would be a valve that is off by default (i dont want it to start overflowing because the power went out or the arduino lost it's mind) that I can easily hook to some small tubing? I would have to take in water from a garden hose, but I could probably use a seperate adapter to get it down to a smaller tubing size, and obviously I would keep the pressure pretty low. Any ideas?
And lastly the actual water detector. I know you can detect a water level using 2 wires and when the water gets over them the circuit completes, but I don't know how well that would work for this. Is there a way I could have it detect how full it is in percent? And if the classic "2 wires" idea is the best way to do this, is it going to make touching the water dangerous? I would think if I used a very small amount of electricity it wouldn't matter, but I don't want to accidentally fry some bird that lands in the water on a hot day...
Help! I really want to do something like this but I'm clueless :P
