Hi everyone,
I have Arch almost how I want it to be, but i have 1 major problem and one little problem. The major problem is the sound. I can't get alsa to work. i installed alsa-utils with pacman and when starting alsa-mixer I get 3 blocks without a bar to set the sound level. pressing f6 and changing to a different device i get a screen full of bars that i can adjust including master. when i change the sound level on the mic i get a really noisy sound (i don't have a mic) so i guess something is working. aplay -l gives this. i'm using the onboard sound and i don't have a soundcard.
**** List of PLAYBACK Hardware Devices ****
card 0: HDMI [HDA Intel HDMI], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
Subdevice #0: subdevice #0
card 0: HDMI [HDA Intel HDMI], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 0: HDMI [HDA Intel HDMI], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 0: ALC1150 Analog [ALC1150 Analog]
Subdevices: 1/1
card 1: PCH [HDA Intel PCH], device 1: ALC1150 Digital [ALC1150 Digital]
Subdevices: 1/1
card 2: Generic [HD-Audio Generic], device 3: HDMI 0 [HDMI 0]
Subdevices: 1/1
card 2: Generic [HD-Audio Generic], device 7: HDMI 1 [HDMI 1]
Subdevices: 1/1
card 2: Generic [HD-Audio Generic], device 8: HDMI 2 [HDMI 2]
Subdevices: 1/1
card 2: Generic [HD-Audio Generic], device 9: HDMI 3 [HDMI 3]
Subdevices: 1/1
card 2: Generic [HD-Audio Generic], device 10: HDMI 4 [HDMI 4]
Subdevices: 1/1
card 2: Generic [HD-Audio Generic], device 11: HDMI 5 [HDMI 5]
Subdevices: 1/1
the other problem is while using a virtualmachinge. i use qemu for windows7pro 64bit and i use another one for achlinux for testing. Windows works fine but graphicaly totaly not. it's good enough but it's a bit annoying. i don't know if i need to install the amd windows drivers (i have an amd gpu). i tried it and i can only install the catalyst control center. -smp 8 gives me only 2 cores for the guest which s also weird to me. in arch, i did a normal install with syslinux base base-devel, xorg-server xorg-server-utils xorg-xinit xf86-video-ati/vesa mesa lxdm installed. x doesn't work for some reason. i think i need some guest drivers but i really don't know which one to use.
EDIT: after rebooting my partition for windowsvm doensn't mount anymore. i commented it out in the fstab and i can boot again but i can't use widows now :(. I created it with qemu-img create -f raw /dev/sdb3 256G. can someone help me with that?
iTr0_0oW
