It doesn't even get past boot, I cant boot to the USB to run anything. When using the option to boot anywhere at all, it freezes. Even when I tell it to boot to the internal SSD. I have to skip the boot options completely by pressing Ctrl+d
did you flash the bios? because from my experience with my acer 710 i couldn't install a linux distro on it like a normal pc. google has seemed to of locked the bios down.
i used this guide. http://crunchbang.org/forums/viewtopic.php?id=27917&p=1
although i'm not sure what's going on with the 720 and how close it is to my 710.
i never said it was for dual boot. and the link was to help him become more informed on the subject. i was just passing along something i found through playing with my chrome book. so instead next time why don't you contribute to helping instead of pointing out shit that isn't relevant to the post.
I just installed arch again on a c720 without hickups.
There are a couple of things I can think of:
1. What image of Arch did you use? Was it an older one? You really should use a recent one.
2. Did you do a hashcheck on the data before you dd'ed it to the USB?
3. Most probable: USB flashdrive hickup. Maybe rewrite the MBR on the USB drive, and while reformatting afterwards with a fresh partition, do a check to see if there aren't any bad blocks on it. I'm pretty sure that there is a data integrity problem on your USB drive that is causing the freeze.
Let me know what it did after trying again with a fresh USB stick, I'll keep an eye on the thread.
Well, I remade the image with dd, using a different USB stick, same problem. I got curious, and removed the stick, and pressed Ctrl+L to get into SeaBIOS, and tried to boot into my internal SSD, and it did the same thing, even with no USB drive.
If I dont press anything at boot, or press CTRL+D, it works and boots into ChromeOS fine.
Leads me to believe there's something wrong with my SeaBIOS.
Yup, that's most probably a BIOS problem. I didn't see it on any install and just asked my colleague that did the installs of the dozen C720's I bought, he's betting on a borked BIOS or a hardware problem.
What if you would use the GRUB of Chrubuntu to boot Arch? For instance, you could take the light MATE OS from the mate community, which is only about 300 MB, and start it up with the edited Chrubuntu GRUB. If that would start, it would pinpoint the problem.
I threw Gentoo on the C720 touchscreen that I grabbed to play with, it took more than an hour to just compile firefox... yeah well, that was a waste of time... lolz.
