Arch linux
hi guys,
finished my build and now i i want to use linux on it:). i have w7 on an old hdd for now and games on w7, but i have an 840 evo ssd and a 1tb blue for linux. i got it burned on a cd and i tried but nothing happened. i think i will try it again with an usb but i don't know if it's possible with my mobo.
2de question: there are some tuts for arch linux and i can simply follow them and do the exact same thing, but you need to choose how many storage you give the os and you can give it 3 different parts etc. i'm confused.
i know arch linux isn't newb friendly but i still want to try it cuz it looks so damn good.
using linux as main os
For your first problem make sure your motherboard is set to boot from the USB/CD.
For the partitions give /boot about 100mb, / (root partition) can depend on how many programs you want to install, most people say about 10-15gb should be fine. Give swap 1x to 2x the amount of ram you have. And give /home the rest of your hard drive (will probably be your 1tb)
https://teksyndicate.com/forum/linux/quick-and-dirty-guide-arch-linux-installation/158212
The formatting is bad, so you cant see all of the black parts, but the only parts you need to actually read are in red.
I haven't ran arch native(only on a VM). But please have the official wiki open and follow along. I get excited when new people try Linux. If you have question be sure to ask us and ask the arch forums as well.
The arch forums actually aren't much help.
Most of the replies consist of "RTFM".
Why do you say Arch Linux looks so damn good? Arch doesn't come with a pre-installed Desktop Environment like other distros, YOU install and configure whatever DE you want. Other distros that come with a preinstaleld DE have it already customized. Take Fedora with KDE for example, I love how they modified the "K" (from KDE) start button to be an "F" (from Fedora). Same with the loading screen, it says Fedora and not KDE.
If you want it to look nice, I think KDE is the way to go. Another good looking DE is gnome, but it feels too restrictive for my taste.
Unless you really want to tinker with your system, I suggest you go with some other distro as your first linux experience. There is some work involved in installing and configuring Arch, definitely a lot more work than you are used to if you have only used Windows.
i don't like the ones with pre installed stuff. i want it to do myself. and it looks pretty nice if you add stuff compared to w7
i prefer this forum and sinds it has a linux part why not? but do you know about the storage thingy? it's weird to me.
Ok, I see.
About the installation part. The easiest way to do it would be to create a single partition for your Arch Linux installation, then use that as the root (/) mount point. / contains all the data that the operating system needs. I am not knowledgeable enough to go into the filesystem hierarchy standard (FHS, for short), but you can check this link for a very brief explanation: https://en.wikipedia.org/wiki/Filesystem_Hierarchy_Standard
/ also contains the user data directory, called /home. If you plan to store your data on different partitions, and not in the /home directory (a typical scenario with Windows), then I think 30-50 GB is more than enough for the / partition. When you come to the chapter "Mount the partitions" from the Beginner's guide, this is what you would actually type (I am calling the partition /dev/sda1, replace it with your own partition name)
mount /dev/sda1 /mnt
That's all. Then proceed to the next step of the installation according to the manual.
What the guide is describing is having a partition for the root directory (/), EXCEPT the /home directory which would represent a different partition.
If you want to use this type of partitioning, then you need a 30GB partition for / (I am going to call it /dev/sda1) and a single partition the size of the rest of your hard drive for /home (/dev/sda2). This is what you would type:
mkdir /mnt/home
mount /dev/sda2 /mnt/home
Hope this makes sense.
thanx!
That's all in the guide I posted. But actually, youll want 3 partitions.
sda1 /boot (1024MB)
sda2 / (30GB)
sda3 /home (rest of disk)
Yeah... forgot about UEFI motherboards, I am using an old laptop right now, with BIOS. My mistake entirely.
First case, /dev/sda1 for the /boot directory (1GB), /dev/sda2 for / (including the /home partition, since you will be storing your files on other partitions):
mkdir /mnt/boot
mount /dev/sda1 /mnt/boot
Second scenario, /dev/sda1 for /boot (1GB), /dev/sda2 for /, and /dev/sda3 for /home (the rest of your hard drive):
mkdir /mnt/home
mount /dev/sda3 /mnt/home
mkdir /mnt/boot
Just reminding you, from the guide:
Note: Do not mount more than one partition to the same directory. And pay attention, because the mounting order is important.
i got a 250gig ssd and a 1tb hdd. what to do?
That's a good question. You should install linux on the SSD for the speed, that's obvious. This comes down to preference, and previous experience, but this is how I would do it:
  • make the 1 GB partition /dev/sda1 to use for /boot on your SSD (/dev/sda1 is arbitrary, it can easily be /dev/sdb1).
  • make one 30 GB partition /dev/sda2 on your SSD to use for the root directory, /, excluding the /home directory.
  • make /dev/sda3 on your SSD to use for /home.
  • use the HDD as storage for your large files. Partition it as one partition, /dev/sdb1, and then assign a different mount point for it after you install linux (like /mnt/data). You can ignore the HDD when installing Arch, you can decide how to partition it, and mount it, afterwards.
Commands:
mkdir /mnt/home
mkdir /mnt/boot
I hope this layout will be useful.
so i need to connect the ssd and install it. after install add the hdd? and can you change it after the install, like changing the 30gig to 50gig?
You can have both the SSD and the HDD connected during the install. Windows doesn't let you control much during installation, linux puts all the power in your hands. If you don't tell it to use the HDD, it won't use it.
You can always modify partition size and location. I use a program called gparted, which has a graphical interface for ease of use.
After you install Arch you can format the HDD and create a partition (let's say /dev/sdb1), create a folder named /mnt/data and then mount that partition on /mnt/data each time you boot. You can do that easily by editing the file /etc/fstab, which tells linux how to automatically handle ("mount") partitions that you don't want to manually mount each time you use them.
You can also do the above during install. After mounting /boot,  create the directory /mnt/mnt/data ("mnt" should appear two times, it's not a mistake) like this:
mkdir -p /mnt/mnt/data
mount /dev/sdb1 /mnt/mnt/data
When you generate the fstab later it should automatically add /dev/sdb1 mounted on /mnt/data each time you boot your computer.
With linux, the choice is yours and only yours. I can't stress this enough, linux does what you tell it to do, it isn't like Windows which has a tendency to do very unexpected things.
hi guys
installing arch atm but i ran into som problems. i need to connect to a host but the ones i try are unreacheble. wifi isnt a option.
i thought installing arch was gonna be a hard time but it pretty funny:)
Well, does that mean you are connected to ethernet, or that you can only use wifi, and it isn't available in your install/livedisk?
i'm connectet with ethernet and i dont have wifi on my pc. im also dutch.
So what is the issue? You don't have connection? It's probably an easy issue of enabling dhcpcd.
In the livedisk, $ ls /sys/class/net. Your ethernet will probably be called eth0, eth1, or eno1. Run # ip link set eno1 up if it's eno1, or whatever your ethernet actually is. Then run # dhcpcd eno1 or eth0, etc. That should be enough for you to have a connection.
