Arch linux wont boot
hi guys
got a problem. i'm trying to install arch linux but i ran into some problems. i downloaded the iso and burned it to a disk and chose boot options and i chose my dvd drive. but then i get a black screen with one white _. same with my usb drive. i downloaded it here: http://arch.apt-get.eu/iso/2014.01.05/
i downloaded: archlinux-2014.01.05-dual.iso
what did i do wrong? do i need all the files from the download link?
What did you use to burn the iso?
freeisoburner, iso to usb
There's your problem - use Cygwin to dd the iso, or perhaps Win32DiskImager.
thanx. hope it works
oke how does cygwin works? i'm a newb:)
The ff.lol? 0.o
If it really is that you don't know how to burn a .ISO than download Ubuntu instead it will save you a lot of future confusion.
And for buring a iso, you don't actually put the iso file on a disk, but you have to put the files which are in the iso on the disk. Any iso burning tool which describes itself as a "iso" burning tool" will most likely accomplish that.
You should not advise Cygwin with dd to a user who does not know how to burn a ISO.. you could just have told him that "isoburn.exe" which is in windows7+ standard could accomplish the same thing.
Even isoburn is doable via cmd
isoburn.exe /q I: "F:\test image\ubuntu.iso".
/q for silent
I: for dvd/cd station
"c:\path\to\file.iso" for the isofile
