Hey all!
I recently built a TRX40 Aorus Xtreme/Threadripper 3960X system where i migrated two GTX 1080s from a gaming rig with the intention to utilize VFIO/IOMMU to pass through one of them to a Windows VM for some light gaming.
The Problem
I installed windows before passing through the GPU. But, when I run Windows 10 VM. It runs but monitor never detects a signal. Nothing in journalctl
stands out but here is some feedback on my configuration. (When i bing up the console it on host side it is just a flashing cursor). This is my first VFIO build so any leads at what to look for is much appreciated.
win10.xml
<domain type="kvm">
<name>win10</name>
<uuid>f40bda08-157a-4ef1-a576-13fa7cbe2e5e</uuid>
<metadata>
<libosinfo:libosinfo xmlns:libosinfo="http://libosinfo.org/xmlns/libvirt/domain/1.0">
<libosinfo:os id="http://microsoft.com/win/10"/>
</libosinfo:libosinfo>
</metadata>
<memory unit="KiB">8192000</memory>
<currentMemory unit="KiB">8192000</currentMemory>
<vcpu placement="static">8</vcpu>
<os>
<type arch="x86_64" machine="pc-q35-4.1">hvm</type>
<boot dev="hd"/>
</os>
<features>
<acpi/>
<apic/>
<hyperv>
<relaxed state="on"/>
<vapic state="on"/>
<spinlocks state="on" retries="8191"/>
</hyperv>
<vmport state="off"/>
</features>
<cpu mode="host-model" check="partial">
<model fallback="allow"/>
</cpu>
<clock offset="localtime">
<timer name="rtc" tickpolicy="catchup"/>
<timer name="pit" tickpolicy="delay"/>
<timer name="hpet" present="no"/>
<timer name="hypervclock" present="yes"/>
</clock>
<on_poweroff>destroy</on_poweroff>
<on_reboot>restart</on_reboot>
<on_crash>destroy</on_crash>
<pm>
<suspend-to-mem enabled="no"/>
<suspend-to-disk enabled="no"/>
</pm>
<devices>
<emulator>/usr/bin/qemu-system-x86_64</emulator>
<disk type="file" device="disk">
<driver name="qemu" type="qcow2"/>
<source file="/var/lib/libvirt/images/win10.qcow2"/>
<target dev="sda" bus="sata"/>
<address type="drive" controller="0" bus="0" target="0" unit="0"/>
</disk>
<disk type="file" device="cdrom">
<driver name="qemu" type="raw"/>
<source file="/home/archie/jails/firefox/Downloads/Win10_1909_English_x64.iso"/>
<target dev="sdb" bus="sata"/>
<readonly/>
<address type="drive" controller="0" bus="0" target="0" unit="1"/>
</disk>
<controller type="usb" index="0" model="qemu-xhci" ports="15">
<address type="pci" domain="0x0000" bus="0x02" slot="0x00" function="0x0"/>
</controller>
<controller type="sata" index="0">
<address type="pci" domain="0x0000" bus="0x00" slot="0x1f" function="0x2"/>
</controller>
<controller type="pci" index="0" model="pcie-root"/>
<controller type="pci" index="1" model="pcie-root-port">
<model name="pcie-root-port"/>
<target chassis="1" port="0x10"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x0" multifunction="on"/>
</controller>
<controller type="pci" index="2" model="pcie-root-port">
<target chassis="2" port="0x11"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x1"/>
</controller>
<controller type="pci" index="3" model="pcie-root-port">
<target chassis="3" port="0x12"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x2"/>
</controller>
<controller type="pci" index="4" model="pcie-root-port">
<target chassis="4" port="0x13"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x3"/>
</controller>
<controller type="pci" index="5" model="pcie-root-port">
<target chassis="5" port="0x14"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x02" function="0x4"/>
</controller>
<controller type="pci" index="6" model="pcie-root-port">
<target chassis="6" port="0x8"/>
<address type="pci" domain="0x0000" bus="0x00" slot="0x01" function="0x0"/>
</controller>
<controller type="virtio-serial" index="0">
<address type="pci" domain="0x0000" bus="0x03" slot="0x00" function="0x0"/>
</controller>
<serial type="pty">
<target type="isa-serial" port="0">
<model name="isa-serial"/>
</target>
</serial>
<console type="pty">
<target type="serial" port="0"/>
</console>
<channel type="spicevmc">
<target type="virtio" name="com.redhat.spice.0"/>
<address type="virtio-serial" controller="0" bus="0" port="1"/>
</channel>
<input type="tablet" bus="usb">
<address type="usb" bus="0" port="1"/>
</input>
<input type="mouse" bus="ps2"/>
<input type="keyboard" bus="ps2"/>
<sound model="ich9">
<address type="pci" domain="0x0000" bus="0x00" slot="0x1b" function="0x0"/>
</sound>
<hostdev mode="subsystem" type="usb" managed="yes">
<source>
<vendor id="0x046d"/>
<product id="0xc52f"/>
</source>
<address type="usb" bus="0" port="4"/>
</hostdev>
<hostdev mode="subsystem" type="pci" managed="yes">
<source>
<address domain="0x0000" bus="0x4d" slot="0x00" function="0x0"/>
</source>
<address type="pci" domain="0x0000" bus="0x05" slot="0x00" function="0x0"/>
</hostdev>
<source>
<address domain="0x0000" bus="0x4d" slot="0x00" function="0x1"/>
</source>
<address type="pci" domain="0x0000" bus="0x06" slot="0x00" function="0x0"/>
</hostdev>
<memballoon model="virtio">
<address type="pci" domain="0x0000" bus="0x04" slot="0x00" function="0x0"/>
</memballoon>
</devices>
</domain>
$ dmesg | grep -i -e DMAR -e IOMMU
[ 0.000000] Command line: BOOT_IMAGE=/boot/vmlinuz-linux root=/dev/mapper/vg_main-rootfs rw mce=off amd_iommu=on iommu=pt loglevel=3 quiet
[ 0.000000] Kernel command line: BOOT_IMAGE=/boot/vmlinuz-linux root=/dev/mapper/vg_main-rootfs rw mce=off amd_iommu=on iommu=pt loglevel=3 quiet
[ 3.697236] iommu: Default domain type: Passthrough (set via kernel command line)
[ 3.887681] pci 0000:60:00.2: AMD-Vi: IOMMU performance counters supported
[ 3.887716] pci 0000:40:00.2: AMD-Vi: IOMMU performance counters supported
[ 3.887733] pci 0000:20:00.2: AMD-Vi: IOMMU performance counters supported
[ 3.887747] pci 0000:00:00.2: AMD-Vi: IOMMU performance counters supported
[ 3.888195] pci 0000:00:01.0: Adding to iommu group 0
[ 3.888219] pci 0000:00:01.1: Adding to iommu group 1
[ 3.888243] pci 0000:00:01.2: Adding to iommu group 2
[ 3.888261] pci 0000:00:02.0: Adding to iommu group 3
[ 3.888280] pci 0000:00:03.0: Adding to iommu group 4
[ 3.888300] pci 0000:00:04.0: Adding to iommu group 5
[ 3.888319] pci 0000:00:05.0: Adding to iommu group 6
[ 3.888342] pci 0000:00:07.0: Adding to iommu group 7
[ 3.888364] pci 0000:00:07.1: Adding to iommu group 8
[ 3.888386] pci 0000:00:08.0: Adding to iommu group 9
[ 3.888406] pci 0000:00:08.1: Adding to iommu group 10
[ 3.888429] pci 0000:00:14.0: Adding to iommu group 11
[ 3.888443] pci 0000:00:14.3: Adding to iommu group 11
[ 3.888496] pci 0000:00:18.0: Adding to iommu group 12
[ 3.888510] pci 0000:00:18.1: Adding to iommu group 12
[ 3.888523] pci 0000:00:18.2: Adding to iommu group 12
[ 3.888538] pci 0000:00:18.3: Adding to iommu group 12
[ 3.888552] pci 0000:00:18.4: Adding to iommu group 12
[ 3.888565] pci 0000:00:18.5: Adding to iommu group 12
[ 3.888579] pci 0000:00:18.6: Adding to iommu group 12
[ 3.888592] pci 0000:00:18.7: Adding to iommu group 12
[ 3.888614] pci 0000:01:00.0: Adding to iommu group 13
[ 3.888635] pci 0000:02:00.0: Adding to iommu group 14
[ 3.888655] pci 0000:03:00.0: Adding to iommu group 15
[ 3.888681] pci 0000:04:00.0: Adding to iommu group 16
[ 3.888703] pci 0000:04:00.3: Adding to iommu group 17
[ 3.888724] pci 0000:20:01.0: Adding to iommu group 18
[ 3.888742] pci 0000:20:02.0: Adding to iommu group 19
[ 3.888764] pci 0000:20:03.0: Adding to iommu group 20
[ 3.888787] pci 0000:20:03.1: Adding to iommu group 21
[ 3.888805] pci 0000:20:04.0: Adding to iommu group 22
[ 3.888824] pci 0000:20:05.0: Adding to iommu group 23
[ 3.888845] pci 0000:20:07.0: Adding to iommu group 24
[ 3.888866] pci 0000:20:07.1: Adding to iommu group 25
[ 3.888890] pci 0000:20:08.0: Adding to iommu group 26
[ 3.888910] pci 0000:20:08.1: Adding to iommu group 27
[ 3.888950] pci 0000:21:00.0: Adding to iommu group 28
[ 3.888975] pci 0000:21:00.1: Adding to iommu group 28
[ 3.888995] pci 0000:22:00.0: Adding to iommu group 29
[ 3.889019] pci 0000:23:00.0: Adding to iommu group 30
[ 3.889040] pci 0000:23:00.1: Adding to iommu group 31
[ 3.889065] pci 0000:23:00.3: Adding to iommu group 32
[ 3.889087] pci 0000:23:00.4: Adding to iommu group 33
[ 3.889109] pci 0000:40:01.0: Adding to iommu group 34
[ 3.889131] pci 0000:40:01.1: Adding to iommu group 35
[ 3.889150] pci 0000:40:02.0: Adding to iommu group 36
[ 3.889172] pci 0000:40:03.0: Adding to iommu group 37
[ 3.889193] pci 0000:40:03.1: Adding to iommu group 38
[ 3.889212] pci 0000:40:04.0: Adding to iommu group 39
[ 3.889234] pci 0000:40:05.0: Adding to iommu group 40
[ 3.889255] pci 0000:40:07.0: Adding to iommu group 41
[ 3.889275] pci 0000:40:07.1: Adding to iommu group 42
[ 3.889297] pci 0000:40:08.0: Adding to iommu group 43
[ 3.889317] pci 0000:40:08.1: Adding to iommu group 44
[ 3.889342] pci 0000:41:00.0: Adding to iommu group 45
[ 3.889416] pci 0000:42:00.0: Adding to iommu group 46
[ 3.889516] pci 0000:42:01.0: Adding to iommu group 47
[ 3.889590] pci 0000:42:02.0: Adding to iommu group 48
[ 3.889663] pci 0000:42:03.0: Adding to iommu group 49
[ 3.889737] pci 0000:42:04.0: Adding to iommu group 50
[ 3.889811] pci 0000:42:05.0: Adding to iommu group 51
[ 3.889845] pci 0000:42:08.0: Adding to iommu group 52
[ 3.889880] pci 0000:42:09.0: Adding to iommu group 53
[ 3.889914] pci 0000:42:0a.0: Adding to iommu group 54
[ 3.889994] pci 0000:43:00.0: Adding to iommu group 55
[ 3.890089] pci 0000:44:00.0: Adding to iommu group 56
[ 3.890172] pci 0000:45:00.0: Adding to iommu group 57
[ 3.890251] pci 0000:45:00.1: Adding to iommu group 58
[ 3.890312] pci 0000:47:00.0: Adding to iommu group 59
[ 3.890367] pci 0000:48:00.0: Adding to iommu group 60
[ 3.890427] pci 0000:49:00.0: Adding to iommu group 61
[ 3.890448] pci 0000:4a:00.0: Adding to iommu group 52
[ 3.890496] pci 0000:4a:00.1: Adding to iommu group 52
[ 3.890513] pci 0000:4a:00.3: Adding to iommu group 52
[ 3.890534] pci 0000:4b:00.0: Adding to iommu group 53
[ 3.890555] pci 0000:4c:00.0: Adding to iommu group 54
[ 3.890591] pci 0000:4d:00.0: Adding to iommu group 62
[ 3.890616] pci 0000:4d:00.1: Adding to iommu group 62
[ 3.890636] pci 0000:4e:00.0: Adding to iommu group 63
[ 3.890657] pci 0000:4f:00.0: Adding to iommu group 64
[ 3.890677] pci 0000:60:01.0: Adding to iommu group 65
[ 3.890695] pci 0000:60:02.0: Adding to iommu group 66
[ 3.890716] pci 0000:60:03.0: Adding to iommu group 67
[ 3.890734] pci 0000:60:04.0: Adding to iommu group 68
[ 3.890753] pci 0000:60:05.0: Adding to iommu group 69
[ 3.890774] pci 0000:60:07.0: Adding to iommu group 70
[ 3.890794] pci 0000:60:07.1: Adding to iommu group 71
[ 3.890819] pci 0000:60:08.0: Adding to iommu group 72
[ 3.890839] pci 0000:60:08.1: Adding to iommu group 73
[ 3.890861] pci 0000:61:00.0: Adding to iommu group 74
[ 3.890884] pci 0000:62:00.0: Adding to iommu group 75
[ 3.891026] pci 0000:60:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 3.891029] pci 0000:40:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 3.891030] pci 0000:20:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 3.891032] pci 0000:00:00.2: AMD-Vi: Found IOMMU cap 0x40
[ 3.894000] perf/amd_iommu: Detected AMD IOMMU #0 (2 banks, 4 counters/bank).
[ 3.894029] perf/amd_iommu: Detected AMD IOMMU #1 (2 banks, 4 counters/bank).
[ 3.894058] perf/amd_iommu: Detected AMD IOMMU #2 (2 banks, 4 counters/bank).
[ 3.894087] perf/amd_iommu: Detected AMD IOMMU #3 (2 banks, 4 counters/bank).
[ 3.910960] AMD-Vi: AMD IOMMUv2 driver by Joerg Roedel <[email protected]>
$ dmesg | grep -i vfio
[ 4.204127] VFIO - User Level meta-driver version: 0.3
[ 407.162926] vfio-pci 0000:4d:00.0: vgaarb: changed VGA decodes: olddecodes=io+mem,decodes=io+mem:owns=none
[ 408.213216] vfio-pci 0000:4d:00.0: enabling device (0000 -> 0003)
[ 408.213500] vfio-pci 0000:4d:00.0: vfio_ecap_init: hiding ecap 0x19@0x900
[ 408.229885] vfio-pci 0000:4d:00.1: enabling device (0000 -> 0002)
My Setup (Due Diligence Details)
I have enabled SVM in UEFI.
I am running Arch Linux with the following installed: qemu
, libvirtr
, virt-manager
, ovmf
. I have gone through the Arch Wiki article here and set up the following boot script:
/usr/local/bin/vfio-pci-override.sh
#!/bin/sh
DEVS="0000:4d:00.0 0000:4d:00.1"
if [ ! -z "$(ls -A /sys/class/iommu)" ]; then
for DEV in $DEVS; do
echo "vfio-pci" > /sys/bus/pci/devices/$DEV/driver_override
done
fi
/etc/initcpio/install/vfio
#!/bin/bash
build() {
add_file / /usr/local/bin/vfio-pci-override.sh
add_runscript
/etc/initcpio/hooks/vfio
#!/usr/bin/ash
run_hook() {
msg ":: Triggering vfio-pci override"
/bin/sh /usr/local/bin/vfio-pci-override.sh
And i have the following in my /etc/mkinitcpio.conf
FILES=(/usr/local/bin/vfio-pci-override.sh)
MODULES=(dm_mod kvm_amd vfio_pci vfio vfio_iommu_type1 vfio_virqfd)
HOOKS=(base udev autodetect modconf block mdadm_udev lvm2 filesystems keyboard fsck vfio)
And here are the boot flags in /etc/default/grub
GRUB_CMDLINE_LINUX_DEFAULT="mce=off amd_iommu=on iommu=pt loglevel=3 quiet"
