So I’ll keep this short, I am trying to install a few apps - most notably polybar for i3-wm, and even though it is on the AUR , pacman through the terminal says the target is not found. I have also done pacman -Syu and pacman -Syy to no success. I’m not particularly sure what the issue could be and any suggestions are helpful!
Hmm that makes sense, So I am trying to install it through the makepkg command, however it stops it towards the end with; /usr/bin/makepkg: line 170: fakeroot: command not found
Yaourt is probably the best AUR package manager. It will search all your repo’s core, extra, community, aur, blackarch, ect…(manjaro and antegros if you use those.
It can easily be downloaded off the AUR…oh wait…lol best off luck
Install the fakeroot package using pacman You may want to go ahead and install the base-devel group, it contains fakeroot as well as other packages needed for building from source.
Thanks for all of the help - Once I realised the AUR doesn’t work like say extra repos do on Ubuntu, I figured it out. I just did it initially installed with the package commands, however have since used and AUR helper.
Just FYI Arch community is very figure it out yourself mentality. this forum is great for help but normally out side this you will get yelled at for this question. Also check #archlinux-newbie. but keep posting on here for more traffic
A couple of things to note after reading these comments:
Be sure to understand the basics of how the AUR and pkgbuilds work before using an AUR helper. Despite the way helpers present it to you the AUR is not just another repo. Its more like a PPA in ubuntu and you should treat it like one.
Pacaur was a good choice but is now unmaintained. I think the most recent Pacman update finally broke it.
As some have said Aurman is a good choice. So is yay.
Read the Wiki.
The Arch Wiki truly an incredible source of information. For almost anything you could want to do you’ll find step-by-step instructions and troubleshooting. The only time the Arch community is unfriendly is when the question is easily answered on the Wiki (like this one ) . Definitely check that out. It’s invaluable.
