Hey guys, i recently installed Arch again and i wanted to use kde like every time. But pacman -S kde wasn't found. So whats up there? In the wiki i read that its in "EOL". What does this mean?
I googled and found a way to install kde but its buggy as hell, no normal networkmanager and a few other things. Is there an easy way to just get the good old kde on Arch i loved?
Thank you in advance
EOL means end of life.
I recommend that you try to look up how to install plasma 5. You might need to do another fresh install.
Oh... Ok thank you. I installed plasma and my l10n language pack but its totally buggy. No Networkmanager like usual and a lot crashes.. But why is this this way? I mean under Debian for example it works fine everything..
No idea.
Even on opensuse plasma 5 is not all that stable.
My recommendation is that you use cinnamon until plasma 5 works out its bugs
Thank you very much, thats what i also considered to do..
