Aquaerro without Aqua Suite
Hello , Is there any experienced Aquaerro user here? I`m planning to use my old Aquerro as a safety device in my future server build.
I would like to preconfigure it on Windows with aqua suite , and then use it as independent safety switch. It will be a watercooled build with flow sensors, temp sensors
and liquid level sensors.I plan to set up various rules for autoshutdown like :
  • when temp gets to a certain level
  • flow gets to low , meaning one of the pumps is dead or there`s a leak
I plan to connect Aquaerro relay to 24 pin atx cable for autoshutdown purpose.
Aquaerro will be running preconfigured directly from psu with no connection to motherboard and with no software.
Has anybody tried similar solution or had any issues with using Aquaerro without Aqua suite ?
