i'm currently playing war thunder on an A6-5200m with Radeon 8400 integrated. it does fairly well on the lower settings (I don't mind) however when I want to increase settings it informs me of resetting because of low graphics ram.
now I know the apu is supposed to draw from my main system memory (4gb 1600mhz) and is stated to reserve 512mb. now my question is, does the apu allocate more ram as needed? how exactly does it work? I would like to change a few settings to get slightly better visuals at least for the aircraft in the game. any help would be nice.
Yes the APU will use more memory as necessary if you have it available. You can dedicate more memory by going into the BIOS and allocating more. It would be helpful to know what sort of motherboard you have or as I see it is a mobile processor, what laptop you have.
That being said, with only 4GB of RAM, Windows and the game and everything else running on your machine will be eating up a lot of memory. I doubt there will be enough to go around. You may want to look into buying some more memory.
There is a pre-determined limit to the amount of RAM the GPU part of the APU can access and the same thing with the CPU. You can change these allocations in your BIOS. If I were you, to prevent this error from occuring, I would change it to around 1GB for the GPU and for the CPU.
That's what one gets for having a big brand machine. They often don't give users such controls even if the motherboard originally has them. At best it might be set to automatically adjust the value on the amount of RAM installed, but you might want to contact HP and ask about that before putting any faith into it.
the next pc I get will be built not bought. but for the 300 I paid for this prebuild, I don't think I did bad. considering it's a laptop that can play some lower end games and it stays fairly cool, never have seen 70c. do plan on contacting hp to see exactly how the memory gets split. would it be wise to upgrade to 8gb of 1600mhz?
I've only played War Thunder a little bit but it did not seem to use very much RAM, so 4GB could be plenty. The CPU also only seem to have a single memory channel so it would not be faster to have two sticks of RAM as compared to one.
