APU MiTX Rig
So it's upgrade season and my gaming rig is going to get some items, a new FX 8350, a 256GB SSD, and Windows 8.1.
I used to have a PS3, but when I moved from the US to South Korea I left my PS3 with my now ex-girlfriend.  I don't really miss the gaming, but I do miss being able to watch Blu-Rays.  The PS4 is taking forever to get in stock, so I figured while I'm upgrading my gaming rig, how about I make a small form factor build for Blu-Rays, Netflix, and World of Warcraft/Minecraft.
I'm planning to put this computer in my bedroom and running two 40" 1080P TVs off it :D... why because I can!
I looked at intel, but then I looked at AMD's "new" APU's, well I'm been looking at parts and there are still a few I'm torn on.
Case: BitFenix Prodigy = Not sure what color, but it seems to be the perfect fit.
Motherboard: ASRock FM2A88X-ITX+ = I like this one because it has an intergrated wireless chipset so I don't have to run lan cables through my apartment, and the layout seems rather practical, also it's from ASRock, and I've used their boards on plenty a build.  On top of that, they support the new A10 7850K that's comming out next month.
CPU: A10 7850K, it's not out yet, but as far as I'm concerned why not go for the best, obviously I'll make sure the bench marks are solid before I commit.
Memory: Now the board supports 32GB, but I can't seem to find any dual channel kits that run 32GBs, so I'm looking at some 16GB kits in the 2133 range, would love some suggestions.
Video Card: R7 260X = I know I don't "need" a dedicated video card, but it looks like a nice choice, not sure what manufacture I should pick.
SSD: 128GB left over SSD = I forgot what I'm using now, but I'll be recycling it from my gaming rig and putting it in here.
HDD: I have one 3.5" lying around here somewhere
Power Supply: Not sure what fits in the BitFenix atm, but I was hoping to get something with 80+ Platinum and modular, atm looking at 650Watts-750 Watts, which might be overkill, but better than underkill.
Blu-Ray: Since I need a drive for the Blu-Rays I'm looking at something 5.25 decent quality and playback.
OS: Windows 64Bit 8.1 OEM
CPU Cooler: Well I'm not sure what I should do here, I was thinking the Corsair H80i or H60, H60 might be quieter.  If anyone knows of a decent Air of All in One Liquid kit that will fit in this build let me know.
I'm pretty sure that's everything I can think of, let me know why you all think and where I can improve on performance in this small form factor, at least as far as AMD APU's go.  I'll build a Intel rig next year.
If you are going to use a dedicated graphics card then there is no point in buying an apu.
Grab a haswell i5. Will be way better. Loads of great mitx haswell boards available as well.
But with a 260x it will crossfire
APUs doesn't support dual graphics with any GPU higher than selected HD 6000 series card
Here some info: http://www.amd.com/UK/PRODUCTS/TECHNOLOGIES/DUAL-GRAPHICS/Pages/dual-graphics.aspx#3
I put together two builds last night, I think I'm going to still go with AMD and just not get a dedicated graphics card, at least not right now.  I'll see how the APU preforms, and if it works for the media and light gaming then I'm golden.
Basically AMD seems to win out with the cost, I do want to make a performance Intel build next cycle.  I do have a question, if I'm using the onboard HMDI and I later add a dedicated card, can I use both the onboard and dedicated HMDI?
you can use both but you have to tweak your BIOS to look for integrated graphics first. it will simply extend your monitors.
You have to either AMD integrated with AMD dedicated or vice versa with Nivda. Mix and match probably result in BSOD.
