APU Cross Fire vs CPU + GPU
Hi,
   I am trying to build a PC. I have 2 option APU based
    AMD A10-6800k Cross Fire with Sapphire AMD/ATI HD 7750 1 GB GDDR5 with ASRock FM2A85X Extreme6 Motherboard.
    or
AMD FX-6300 with Sapphire NVIDIA GTX 650 Ti 1GB GDDR5 with MSI 990FXA-GD65 Motherboard.
If i change FX-6300 to FX-4300 price are almost identical, with FX-6300 now its around र 600-700 (Around 10$).
So which one would be better?
Go with the 6300 and a 7750.
Isn't 650Ti better than 7750?
i would suggest FX6300 with Asus M5A97 R2.0 mobo and GTX-650 ti Boost. or if you can afford a HD7850.
https://www.vibox.co.uk/news/graphics-cards/amd-a10-6800k-apu-crossfired-with-xfx-hd7750
It is doable but not suggested, since you will introduce microstuttering and other problems generally associated with cf. save up and get a 7870 and fx6300.
