Approx $1800 build, Australia
Greetings, forum. Being my first post. take it easy on me.
Anyways, I, very soon, will be getting my first build. Now, Im not going to call myself a noob because 1. It makes me look like a 13 year old and I hate 13 year olds, and 2. I do know a fair bit considering i have done about 8 months of research.
I would like the i7 3770k and 7970 ghz edition incorporated in the build but apart from that, its up to you people.
I do have a build sort of formulated but it is very blurry because i keep changing things.
Keep in mind this is for mostly gaming but also video editing in the very near furure. Also this is from AUSTRALIA, and i will be buying from PC Case Gear.
Thanks a bunch and happy Easter!
$1800 in America - awesome computer capable of so much
$1800 in Australia - Intel core duo and a complimentary packet of jaffa cakes and tissues to make you feel better XD
CPU: Intel Core i7-3770K 3.5GHz Quad-Core Processor ($345.00 @ PCCaseGear)
CPU Cooler: Thermaltake Water 2.0 Extreme 81.3 CFM Liquid CPU Cooler ($155.00 @ PCCaseGear)
Motherboard: Asus Maximus V Gene Micro ATX LGA1155 Motherboard ($229.00 @ PCCaseGear)
Memory: Corsair Vengeance 16GB (2 x 8GB) DDR3-2133 Memory ($199.00 @ PCCaseGear)
Storage: Intel 330 Series 120GB 2.5" Solid State Disk ($125.00 @ Scorptec)
Storage: Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive ($69.00 @ PCCaseGear)
Video Card: Gigabyte Radeon HD 7970 GHz Edition 3GB Video Card ($469.00 @ PCCaseGear)
Case: NZXT Source 210 (Black) ATX Mid Tower Case ($65.00 @ Scorptec)
Power Supply: Silverstone Strider Plus 750W 80 PLUS Silver Certified ATX12V / EPS12V Power Supply ($145.00 @ PCCaseGear)
Optical Drive: Samsung SH-224BB DVD/CD Writer ($22.00 @ PCCaseGear)
Total: $1823.00
That should do you well. You could cheap out on the PSU if you wanted but that PSU is amazing and you will thank me in the long run
For god's sake, create the build on pcpartspicker, no one has time to sort through this.
Also you'll have two more slots free for ram should you wish to bump up to 32gb in the future
Total: $1823.00
There thats a little easier to make out
You's can use pc part picker if you want.
Thanks man, really helps.
http://au.pcpartpicker.com/p/MUsK
CPU Cooler: Cooler Master Hyper 212 EVO 82.9 CFM Sleeve Bearing CPU Cooler ($35.00 @ PCCaseGear)
Motherboard: Asus SABERTOOTH Z77 ATX LGA1155 Motherboard ($249.00 @ PCCaseGear)
Memory: G.Skill Ripjaws X Series 16GB (2 x 8GB) DDR3-1600 Memory ($145.00 @ Scorptec)
Storage: Western Digital Caviar Black 1TB 3.5" 7200RPM Internal Hard Drive ($99.00 @ Scorptec)
Storage: Samsung 840 Pro Series 128GB 2.5" Solid State Disk ($149.00 @ PCCaseGear)
Video Card: Asus Radeon HD 7970 3GB Video Card ($469.00 @ Scorptec)
Case: NZXT Phantom 410 (Black) ATX Mid Tower Case ($129.00 @ Scorptec)
Power Supply: Antec High Current Gamer 750W 80 PLUS Bronze Certified ATX12V / EPS12V Power Supply  ($135.00 @ PCCaseGear)
Optical Drive: LG GH24NS95 DVD/CD Writer ($25.00 @ PCCaseGear)
Total: $1780.00
Difference between WD Blue and Black?
The black is a faster drive lower seeks, faster read and writes
Don't quite unerstand why yours is so expensive? Apart from the difference between blue and black, my choice of parts rips the balls off yours. Why?
Your pick has Corsair Vengeance ram (shit cheap o ram)  and 2000+mhz is just not needed and  possibly unstable
The mobo is a M-ATX  (realy)
A not needed water cooler and a cheap case
The parts i picked go better together better,the mobo it a A-TX with a better Phase Power Design and is more suited to over clocking the Hard drive and ssd are about the best you can get
G skill ram is the best (that i can find in the australian area) and will over clock as much as needed
There is allso a more expencive case
Maybe do some research before you just random pick things that sound good on paper.
Whats wrong with 13 years olds?  (im 16) but whats wrong with it?
anyway, i found this setup:
http://au.pcpartpicker.com/p/MZSI
let me know what you think... grtz Angel ☻
p.s you can allways decide to switch the cpu cooler to a LC cooler i left room for it ☻
i like angel's build the most, but if you some extra money in your budget go with a sabertooth
Thank you i realy like that.
The reason i choosed the MSI is cause its the little brother of the x79 X power aka (big bang)
The z77mpower gets handtested out of fabrick, they  tested those board with an i5 3570k oc to 4.5 ghz or so for over 24 hours, on full load. So that gives you the guarantee, that its working realy good, cause they get hand tested out of fabrick,And i personaly think its one of the nices´t z77 board to but. i love it.
Thanks everyone,
1. Is the bitfenix shinobi xl a good case?
2. Is the MSI z77a-dg65 a good choice also
3. Is kingston or g.skill better overall?
4. Is the silvertone strider plus a good psu.
5. Lastly, is the intel 335 180gb a good ssd?
Apart from the cpu cooler i think its a good way to go.
