Trying to find the %AppData% for macOS. Need to reset OBS settings. Anyone know where that’s at?
I think I got it. It’s X > Users > Y > Library > Application Support
X = Your Mac OS drive/partition name (for example: Macintosh HD)
Y = Your Mac account name
There is no exact equivalent to the %AppData% folder in macOS. However, all of the settings for OBS are stored in the Library folder in your home directory. You can open this folder by clicking the Go menu in Finder, then select Go to Folder and type in ~/Library. From there, you can look for the OBS settings folder.
