The BIOS is buggy in several ways. For example, setting “AUTO” “System Memory Multiplier” does not correspond to the XMP values correctly, you have to set it manually.
“Option Description” text is cut off and it is unable to read below lines, oddly you can drag the incomplete text around with mouse.
At this point I am worried about my voltages, I must check out them in HWInfo because I can’t trust the “Auto” values.
