Hi I am about to upgrade from my really old PC witch cant run games anymore. Since i am not 18 i dont have a job or a credit card so i don't have much money.
This Is the PC i will make:
http://pcpartpicker.com/user/PCGamerUnion/saved/4EdH
Just tell me if there is anything wrong with this and it you would change anything.
I cant go over 600$ tho.
Try something like this: http://pcpartpicker.com/p/3GUWO
2GB of ram just won't cut it these days. You can still go for 750Ti, but ram is just too low in my opinion.
http://pcpartpicker.com/p/3I0yw
This is what I would do the cpu will last you a long time and you can just upgrade the gpu.
Trying to stay within the budget, and maintaining the features you picked:
http://pcpartpicker.com/p/3Ib1L
