The OS fresh install did the trick!! And with everything attached on the fresh install everything are working smoothly even the corsairlink software is working pretty good :) Luckily I only had 1 game on the ssd and a few files ;) got them back straight away anyway, just transferred them from the "windows.old" folder good thing they do that when you install your OS again so you can transfer files from old to he knew installation :) Thank you for all of you input :)
ps: Esr- I turned the machine off when I unplugged the fan header.
