[color=#FFFFFF]Anyone gettin their GTX 4xx cards delivered tomorrow? I've been starring at my UPS tracking all week. Im about to explode. And you know what kind.[/color]
Cancelled mine.. Figured I need the money.. And I wont be using pc as much when its sunny outside anyways.
Buying it later
Might wait and see if the heat issue is a lie.
It is a lie kinda... Well, not if you use auto fan function.
Ive read that if you keep it to manually 70% when gaming, it wont go above 70C
70% would make you pretty much deaf, but it depends on how loud the card actually is.
I am going to wait until the end of the year to get a new card. Just to make sure.
It uses a delta fan so I give you about a month till you need hearing aids.
I keep my card at 100% and dont even hear it over my metal!
Well, loud Metal fixes everything.
:jumping high five:
Indeed
