Anyone check out the Lian Li V33?
Just looking for a new case thats large enough to hold my 200x150x86mm psu, two large gpus, easy to clean out the filters, aesthetically looks clean, and is as light and durable as possible. Also, I'm concerned about durable feet, my current case is an Antec Twelve Hundred v3, just has rubber feet glued on, that fall off.
I saw the v33 without the tempered glass side, haven't been able to find many detailed reviews of it, but it seems way lighter than every other case i see that i would be confident in being spacious enough (probably because of the cube design), its wide and low, which i guess is good if i ever get a dog or cat as they can't possibly knock it over, and the feet look higher quality, and its Lian Li which i understand has a pretty good reputation for quality. (no i'm not a Lian Li salesman)
Any thoughts on it or maybe cheaper cases you think would fit the bill?
