Hi guys n girls,
I made a small virtual network in Oracle Virtualbox to test out pfSense. I'm currently trying simulate a CARP failover, but I'm missing a switch. I managed to install Open vSwitch on Ubuntu, but the only tutorials I can find are for setups with virtual machines on (= in) the Ubuntu box. What I want to do is give my Ubuntu VM 4 virtual interfaces and let the VM act as a switch inside Virtualbox. (If you get the impression that I'm in over my head you are spot on :P)
Anybody knows if what I want can be done and if so how to configure that thing ? C'mon Wendell, dont be shy, help a brother out here ok :P
Thanks in advance y'all.
Edit: Ow yeah completely forgot: this is what I want to make:
http://www.howtoforge.com/how-to-configure-a-pfsense-2.0-cluster-using-carp
Edit 2: Or can I just replace the switch with a router? (see diagram in link)
=> nope, can't use router because it needs a gateway, switch uses whatever path available.
