I also have 1- 24 in monitor and 2- 19 in monitors where if possible i might as well use all three since i have the space and i don't want to waste them.
That won't be a bad computer if you throw a new mobo and cpu in it, go find a used 2500 and motherboard for it and you should still be good for a while as long as you don't want to play crysis with the hires texture pack.
Oh yea missed the DDR2 memory, but memory is dirt cheap.
I agree with these guys. Get a new motherboard, CPU, and RAM, and everything else should be fine. You could always get a better cpu cooler if you want to spend a little more money too.
I plan on just switching to PC Gaming with this computer. Alot of media, i.e. bluray movies etc. I also plan on learning how to use photoshop and image editing eventually.
well if you already bought it, its decent, there are better choices out now with the 7000 series price drops like the 7870 which is around the same price
Ok guys, sorry i haven't responded back. But tis the season to shop. With Xmas and sales around the corner, I was wondering if there were any good sales and suggestions to bring out some good potential in my computer. I am open to upgrading the MB/CPU/Memory and I am still determined to set it up with a 3 monitor set up, which means either SLI with 2 -GTX 560 ti fpb or switch it out with one amd radeon 7970 which should support 3 monitors with eyefinity.
Any suggestions folks? Happy Thanksgiving and Black Friday!
So should I go then with 2 7970's? Or just stick with the Nvidia card and get another GTX 560 ti?
But still does anyone have any suggestions for the CPU/MB/RAM? I am down to purchase a i7 and just need to wait for a good combo deal. I dont plan to overclock either.
