I built my first pc yesterday and have had a few problems. I have solved several of them but then I made a mistake.
I was setting up my new computer using a program, i dont really remember the name of, I think it was something like "AMD vision engine" or something similar. My problem is that I clicked on a little box titled "Configure Sync" (or something similar) and now my screen is black. When i restart my computer i can get access to the BIOS and everything and when i exit that i get a windows loading screen. But after the loading screen i get a black screen and nothing i do can change it.
I was wondering if there was something i could do with the hardware that would reset or change what i messed up?
Also if anybody knows what to do without messing with the hardware that would help alot too.
Any advice is appreciated.
