Here is what I have so far I just need any suggestions on what I should get that is better than the parts I have chosen. I will be mainly using the pc for gaming and video rendering and editing. I will be playing at 1080p but will be going to a higher resolution later on (after I get a new monitor.) and I want to play at max settings on all games with a decent fps. I will be overclocking the cpu and gpu. I am not changing the peripherals as I really like the ones I have chosen. I live in the uk and I’m buying from America as it is cheaper than buying from the uk.
http://pcpartpicker.com/user/12stiggy12/saved/2TF3
any help will be much appreciated:)
