Any recommendations for a usb c or usb a dual hard drive dock with clone
Unfortunately, my trusty Inateck hard dock blew a capacitor yesterday. Sadly I cant find it on ebay or Amazon. It is the usb c version and they have for some reason discontinued it
However, I do find a lot of hard docks that have usb b for some unknown reason instead of the more modern and versatile usb c option or even bog-standard usb A.
So I am asking what dual drive hard drive docks with cloning do people here use?
Any recommendations that are as good my Inateck hard drive dock Please?
Update
I dont even think I could repair such ribbon cable as the connectors are very close to each other and seams to have torn slightly. I have put in for a Unitek Type C to SATA Dual Bay Dock Station which looks esaclty the same model as Alxum USB C & USB A Hard Drive Docking Station just with a different text on the front. Like, even the clone button, shape and all are the same. Why is that?
why not replace the cap?
I did think of that and i did look and see if i could find a cap, but I also noticed that the Ribbon cable is starting to come away from the pcb board.
Might be able to find one of those too but yeah becoming quite the process at that point.
Sorry dont have any suggestions as I dont use cloners
Pictures? Could be easy to fix.
Riboon cable coming away
Blown capacitor that started this problem
That ribbon is fixable.
I would desolder it from the board and attach it to a 10-pin header, then solder a 10-pin socket into the board.
The capacitor, put in a probably better than factory one :wink:
Parts cost, $1.92
yeah ribbon seems not that bad
