Can anyone see any problems with this build and what fps would i get on dayz and bf3
CPU: Intel Pentium G860 3.0GHz Dual-Core Processor (£50.92 @ Aria PC)
Motherboard: Gigabyte GA-H67N-USB3-B3 Mini ITX LGA1155 Motherboard (£59.19 @ Amazon UK)
Memory: Crucial Ballistix sport 4GB (1 x 4GB) DDR3-1600 Memory (£15.20 @ Amazon UK)
Storage: Western Digital AV 250GB 3.5" 7200RPM Internal Hard Drive (£24.35 @ Aria PC)
Video Card: Asus Radeon HD 7750 1GB Video Card (£74.99 @ Ebuyer)
Case: BitFenix Prodigy (Red) Mini ITX Tower Case (£59.25 @ Amazon UK)
Power Supply: Corsair Builder 430W 80 PLUS Certified ATX12V Power Supply (£34.15 @ Aria PC)
Optical Drive: Lite-On iHAS124-04 DVD/CD Writer (£11.13 @ Amazon UK) Total: £329.18
Theo
April 1, 2013, 7:25pm
#2
What is your budget like? Or with those specs are you pushing it? I'd change the cpu for something a bit better but if thats out of your range then its fine i think!
I just can't help but feel that it is a waste of that case... The main problem is that you should never go any lower than a Radeon HD 7770, regardless of the CPU in question. And at some point in the relatively near future you should add another stick of the same RAM, since 8GB is really the standard nowadays, and dual channel does help a bit.
i just couldnt find a build to do with the fractal design core 1000 for around £330
All should be fine, except i think you might be better of getting a similarly priced AMD chip cause they seem better value.
tony_y
April 8, 2013, 2:41am
#6
Get a intel core i3 and an extra 4 gb or ram
No, no i3! 6300 is so much better.
id go a10 5800k if you can
