Any comments in my build? Badly needed
Any comments about my build?
CPU: AMD a10-5800k
Mobo: MSI FM2-A75-A75IA-E53 DDR3 MINI ITX MOBO WIFI
RAM: 2X4GBX1KIT CORSAIR VENGEANCE DDR3 1600
Storage: 3.5" SEAGATE BARRACUDA 7200 1TB ST3100052A4AS
GPU: POWERCOLOR HD6570 2GB DDR3 128BIT
AEROCOOL STRIKE X 600W
what is youre budget? cause you would probably  get a nicer performing system with an AM3+ build
+1 for AM3+ build. It is always worth building a system that you can upgrade later.
[br]If you are on a tight budget, the A10 is a pretty good APU. I'd save the money on the 6570 and save for a better medium-tier graphics card. The APU will suffice on its own and give enough performance to game at 720p. Without a dedicated GPU, you would need the fastest RAM you could afford to get the best performance out of your A10
Thanks for the ideas. Uhm my budget is kinda low about $400-$500. Can you come up a build for me? I do play games but not that hardcore. Thanks.
http://pcpartpicker.com/p/VM1R
CPU: AMD Phenom II X4 965 Black 3.4GHz Quad-Core Processor ($84.98 @ Outlet PC)
Motherboard: Gigabyte GA-970A-DS3 ATX AM3+ Motherboard ($70.98 @ SuperBiiz)
Memory: G.Skill NS Series 8GB (2 x 4GB) DDR3-1333 Memory ($58.99 @ Newegg)
Storage: Seagate Barracuda 500GB 3.5" 7200RPM Internal Hard Drive ($54.99 @ Amazon)
Video Card: XFX Radeon HD 7850 1GB Video Card ($139.99 @ NCIX US)
Case: NZXT Source 210 (Black) ATX Mid Tower Case ($34.99 @ Newegg)
Power Supply: Corsair Builder 500W 80 PLUS Bronze Certified ATX12V Power Supply ($52.99 @ Amazon)
Total: $497.91
Thank you. I will try these build if the parts are in the store here in my location.
You will get much better value buying online than going to a store -- for instance my local stores best gpu is a Nvida gtx550ti and its been siting there for so long in the window the box is faded and thay what £120 for it!! (a £50-60 card)
