i need to use it but not sure if its safe.
Is there a reason you don't want to manually install drivers ?
Its really quite simple and downloading a 3rd party program isn't necessary as you dont know what they could be doing regarding bloatware and what not.
I can give you a hand if you want ?
i downloaded it and am afriad of malware
Well if you have decent virus protection you should be ok, such as Malwarebytes AntiMalware, Avira, AVG.
It might seem daunting but driver installs are really quite simple, and easy! :)
What operating system are you on and do you have anti virus programs installed ?
sorry, for the late reply its that i have windows idle my memory and its not normal and i found a program that finds all my drivers that i didnt know i had to update
