Any ATX MOBOS under $80? HELP
looking for a mobo that will fit my budget. ATX board that will support AMD FX series CPUs, anybody know of any?
Are you looking to buy or just for recommendations? If you're looking for recommendations you should look at the
Asrock 970 extreme 3 it's $79 with a MIR of 10 dollars on newegg
Some overclocking capability as long as you keep the vrms cool.
I have my fx 6300 at 4.1 ghz and its running fine.
if you're running an 8 core then this is fine too unless you want to overclock
^_^
I plan on getting that CPU and would like to OC so thanks this helps a lot!
In Canada it's $115 :(
There aren't any in the sub-80 range and you realy have to go up to about 100 to get a quality board, i'd suggest this one at 103; http://ca.pcpartpicker.com/part/asrock-motherboard-970extreme4
i would recommend a FX6300 with an Asus M5A97 R2.0 board, if you on a budget.
