Any Advice?
Current I am working on a build that a friend and I both plan to put together, but I am not sure if there is anything wrong with the build. We do not want any bottlenecking in the build. The the build is going to be a gaming/editing rig. Any advice or changes? I am currently using PCPartPicker to make the build.
CPU: i7-3770k
CPU Cooler: Hyper 212+
Motherboard: Asus P8Z77-V LK
RAM: 16GB 1600Mhz (Brand Keeps Varying)
SSD: Kingston Hyper X 3K
HDD: Seagate Barracuda 2TB
GPU: MSI GTX 560 Ti Twin Frozr II
Case: NZXT Tempest 210
PSU: OCZ ModXStream Pro 700W (Always 80+)
seems okay check psu for any future upgrades you may make
Your going balls deep with the CPU. What are you going to be using this computer for?
I plan on using it for recording games with fraps and editing with Adobe Premiere Pro and After Effects.
I would spend another 60 to 80 bucks and grab a 660ti, like the MSI http://www.newegg.com/Product/Product.aspx?Item=N82E16814127697
This is something I will look into.
Here is some benchs between the two cards http://www.anandtech.com/bench/Product/547?vs=647
Wow! I am looking at those benchmarks and I see what you mean.
