When browsing the internet I constantly have problems loading web pages and sites. Its not just limited to sites in Chromium, but even opening discord could have trouble connecting. If I turn my ethernet off, and on then the site will load like there was no problem.
I wonder if its an issue with the network stack in Antergos/Arch and re-installing it would be a fix.
I have Antergos installed on my laptop (Dell Inspiron 15 5737) and there are no problems, and I have had a previous Antergos install on this machine without problems too. A re-install of the whole system would probably fix it, I just don't really want to do that if I don't need to.
This is a system I have been running for a couple of months now, just getting around to fixing this annoying problem now. Its been updated numerous times.
yeah, i'm not sure what it is. I could try and re-install the network stack, but figuring out what packages need to be re-installed could be fun. Might be a good idea to do a kernel re-install too, but I don't think that will help at all since i've gotten a few kernel updates since installing.
