Let's take a quick look at this awesome value case from Antec! Introducing the P70.
This is a companion discussion topic for the original entry at https://teksyndicate.com/videos/antec-p70-case-review
What the hell is this gibberish?
Edit: Now that it's fixed this looks like a shitty comment. Oh well.
I liked the review, for the record. :P
Discourse has a difficult time grabbing the content from the actual post. Wendell has been figuring out a fix but there are other things on his plate too so I think we just aren't there yet.
This looks like a nice budget case. I just bought the Cooler Master Silencio 352. I'd recommend taking a look at it next. I think you'll find it a lot more premium. It is now my go to budget case to recommend to everyone. Sound dampening foam + fan grills = awesome.
Ah....Antec.... it's funny, i built my current system in a P100, one of my best friends has a P180 and another geek friend has a P280 ...we're like the Antec P Club Pals.
I'm liking their 380 case, staying with teh P(ee). Sometimes wish my case had a window, then again, i didn't build it with it being windowed in mind so i'd need to work on color matching and whatnot.
Are we really not done with pci slot covers that need to be popped out with a screw driver...
I have to agree, they can't be that much more expensive. If they would to save on the labour just include them with the case but not installed.
This case looks to me like Zalman Z3 Plus with different plastic... Similar internal layout, similar HDD cage and mounting and everything, similar fan mounts... It doesn't have the GPU support bracket, and it doesn't have a window, but otherwise it looks to me exactly like Z3 Plus with different front and top plastic...
