Antec 900 vs Antec 902
I bring this topic up because it's been bothering me for a while now. I don't really see the difference between the two cases. Is the price difference reasonable for the differences (if there are any)? Or are these just two simply different cases?
So yeah, can anyone help me fix this problem of mine? I ask this, because I'm thinking about getting one of these cases.
900
I own the nine hundred. I bought it 4 yrs ago. Don't buy it, its crap. Buy a bitfenix with dust filters and cable management! Trying to get out of this hardware coffin!
Don't get either. I've owned 3 antec case: P183 V2, 900 and the 'One'. They are made very well but the noise is unbelievable, cable managment is shocking and watercooling support doesn't exist. Save you self the hassel and get Fractal, Nzxt or something.
Save yourself the trouble of having to vaccuum out the fans every week and get something else. I have a 900 and the thing has internal air pressure issues. It uses a negative pressure in the case and it stays pretty stagnant inside. (i7 920 had to have the HT disabled due to the air not getting moved enough...)
I had the 900 for about a year and it's a cool case, but very outdated. Get something with cable managment. If you really want to go with Antec, I'd recomment the Antec 1100. Looks good and has alot of nice features. And it's almost the same price! like 5 dollars more than the 900..
