Hey guys! I posted a thread about my original build about two weeks ago, and after help from here and revising my list, I've changed many things, including the CPU and GPU. Keep in mind that this is a concept, and any criticism is appreciated, especially on the sound card, anti static mat, memory, CPU cooler, and monitor. I’m extremely considering not getting a sound card, but I heard it is good to have if I plan on getting quality headphones, so I’m not sure.
I picked this GPU because I wanted a Radeon 7950, and the less pricey were out of stock, and I saw Tek do a video on it, so I went with this GPU.
The anti-static mat is there because since I’m new to builds, I don’t want to kill any of my parts.
Thoughts on the thermal paste would be nice too, because after some research this seemed like a great option.
Also for the PSU, I picked 700 watts because it was only five dollars more and more doesn't hurt at all.
Total cost of all of this is around $1460, and my budget would be around the 1.5K mark.
Link to build: http://pcpartpicker.com/user/generaltaco19/saved/2t8Z
Thanks for all the feedback! :D UPDATE: Sound card removed because of some feedback, so price dropped to 1,460 USD.
Ok, so I skimmed over it. Don't see anything major. Don't see much minor either that isn't up to opinion. The only thing noteworthy is your about 350 watts over on the power supply. But that is fine if you want the option to crossfire in the future. But at that one's price point you could go for something like these (90-120 range ignore the ones after that). Which output much smoother power at better efficiency.
I honestly got the extra watts I clearly did not need because I would want to reuse the PSU for a later build when I could afford it, but if PSU reusing is not a good idea than I would downgrade my PSU. Thanks for the feedback!
I would pirate anything and have no guilt but I'm just too lazy and spending money to get it easily sounds easier. For a better GPU, I've searched around and seen that this is a pretty solid GPU. Any recommendations you would drop?
