http://pcpartpicker.com/p/2eoe2
I was thinking about the fx 6350, but then I saw that deal on the 8350 lol
So I will use this to replace my xbox 360..
As of now, I haven't decided on a graphics card. I was thinking about a 7870 then maybe upgrade to dual 7870s or just buy one 7970. Any suggestions are welcome.
go with a single card. if you're looking for a 7970, i would get an R9 280X instead. It's the same exact GPU (just newly re-branded) and it's cheaper. that card is only $300 and hits a nice sweet spot for price/performance.
Yeah I'd grab the R9 280X. You also don't need that huge of a power supply and I personally prefer the Asus M5A99FX Pro...
oh, yeah, that PSU is overkill lol. honestly, a 500w PSU is more than enough. Just get a quality brand like corsair or seasonic. beyond that man, it's a pretty solid list.
Thanks for comments guys. Do you think I could get away with a 970 series motherboard instead of the 990? I don't plan on overclocking. I thought the benefit of the 990 series over the 970 was better overclock ability. But correct me if I'm wrong. Is it worth saving the $30 for the difference?
If you aren't going to overclock then don't bother buying an after market cooler. That just saved you $25, so you don't have to worry about downgrading your mobo to a 970 series. I'd stick with one card at the moment, either a 7870 or if you can spend a bit more get a 280x. If you don't like AMD stuff then try a GTX 760, but I don't think it will be as good as a 280x for the price.
If you want to save even more cash buy a 8320 and get an after market cooler to over clock it. It is exactly the same CPU as a 8350, just that the 8350 is factory overclocked.
Good luck with the build :)
You should be fine with the 970 if you aren't overclocking or gonna use SLI/Crossfire.
No I would get an aftermarket cooler regardless. The stock ones are loud and run fairly hot. Better off spending the extra money now.
I think I will only need a 270x or a 7870. I'll just be doing 1080p gaming.
Any major reason to get a 270x over a 7870?
I just made a revision to the build, I dropped the ssd.
http://pcpartpicker.com/user/hunter8793/saved/32VI
Is that a decent $700 build?
Biggest reason to get a 270x for you would be the price. Most of the 270x on newegg are cheaper than all the 7870s. eg http://www.newegg.com/Product/Product.aspx?Item=N82E16814127761 . Never heard of powercolor though, which is $40 cheaper than this card.
270x is just a rebranded 7870 but it's got a decent performance increase over the older card. I'd say the 270x would be getting more support at the moment too, seeing as it's amds latest release of cards too. The 7870s are starting to disappear... Out with the old, in with the new
I'd seriously consider the 8320, seeing as you are buying an aftermarket cooler
you can overclock the 8320, but you never get the same clocks as just getting an 8350, My buddy has two 8320s and he cant get either stable past 4.5 Ghz on custom water loops
Crossfired 7870 is whipping ass and taking names but only under certain conditions. A7950 7970 280 280x will be more future proof . What a idiot concept ( future proofing is) . For 1080p a pair of crossfire 7870s are pretty hot for what it is. 1440p okay? maybe, but you would be be served with 3 gigs of vram
OH and grab the 8350 not a 6 core . Always get the top of class for AMD. Think of the six core as a office computer build with a little grunt for graphics. Then skip over it to the 8350 and life will be good. :)~
Thoughts on this? http://pcpartpicker.com/user/hunter8793/saved/33mn
Oversized PSU and another Cheaper CPU Cooler....
