http://www.youtube.com/watch?v=z6IH2D_dBeU
made me want to double facepalm.....
Intel Ci7-4770k, Z87, 16GB,2xVGA/SSD, 12X,Case/PSU
Intel Core i7-4770K Processor (8M Cache,3.50 GHz)
Asus Intel Z87, ATX Socket LGA 1150 Sabertooth
Intel Extreme Master Viper 3 DDR3 8GB 1866MHz Kit X 2
EVGA GeForce GTX 660 SIGNATURE2 LE 2GB GDDR5 PCIe X 2
Neutron GTX Series 240GB SATA III SSD X 2
ASUS 12X Blu Ray Burner Retail
Corsair AX1200i Digital (DSP) 1200W Power Supply
Corsair Graphite Series 600T Mid-Tower Case (currently available in White)
Because the Sabertooth is the best motherboard evaaawwr
-_-
The word "efficiency" came out his mouth, just as I saw the AX1200i lawl.
Sure, digital rail switching, and Corsair, Corsair, Corsair (because, naturally, their PSUs that they don't make, and sell for a $200 premium, are the best) makes this rig so much more efficient than a PSU half the wattage, and 1/3 the cost.
Keep in mind the price of this build is $2200
Corsair automatically makes it cost effective versus an appropriate sized Seasonic, simply because it matches the brand of chassis.
Zero points picking blue RAM which contrasts with absolutely everything else. Yuck.
Wow, that budget would have fitted 2 780's...
Well i would personaly build a diffrent system with GTX780 for less ☺
Also that psu is way overkill, and the Mobo asus sabertooth z87 with plastic cover plate,and annoying loud little fan.. is also not the kind of board i would personaly go for, i would trow in a Msi Mpower Max or Xpower, at such kind of budget. that are much better boards then the sabertooth.
