http://pcpartpicker.com/p/AlwB
new build above.
new build above.
will probably use linux 99% sure
and would love feedback on it's performance
amd gpu http://pcpartpicker.com/p/Am4f
nvidia gpu http://pcpartpicker.com/p/Am4L
and for both builds you could easily use the stock cooler untill you can buy a better one.
are those two builds same in performance or different
they are very close to the same if you need cuda for something then the nvidia build is the way to go my be with a 660 if you cant swing for the 660ti. if you dont need gpu prower then keep the 650ti or go with a 7850 gpu http://pcpartpicker.com/p/AmA6 and a 8 core cpu
maybe i will get the HIS iceQed 7870
