So, I will be using the Angular framework to develop a website. There will be situations where I am away from my desktop and I do not yet own a laptop. Can any one recommend an online IDE?
I think I will just install Webstorm on whatever computer I need and use Git to pull/push whatever files I need. This is not ideal (in fact it is a rather stupid way to do things), but so far cloud IDEs aren't really hitting the sweet spot for me. Codenvy.com comes close but does not handle the automatic deployment and live browser refresh.
As far as Angular CLI goes, it's great. Still getting the basics of components down but I can build simple stuff. Over the next few weeks I will start to build up a nice little sandbox/boilerplate/kitchen sink ... whatever you want to call it.
This problem is not yet solved. Minus a laptop, an EASY solution does not exist. I will just be buying a laptop. I looked at CodeAnwhere but they only allow you 1 instance for free.
