Android TV box
Good time of the day, community.
Recently bought my first 4K TV (call it a childish dream).
It came with a Tizen smart TV option, from which I didn’t expect even something (but it actually performed quite well… for an isolated OS with a small developer pool).
So I’ve started working in the direction of that one true question of buying a decent android-tv box. Aaand, of course, came to the realization how poor my knowledge of that topic is.
Hope that maybe here people have come across several of those and could maybe share their experience.
And yes, I did google. Quite a lot. But going from that one “Best of the best” (no, sir, not sponsored whatsoever…), came to the realization that part of them can’t be found in the country I live in (west europe). The other part even by the looks like something from AliExpress…
So, if someone would be so kind as to help, here is what I’m looking for:
An android (based?) device with HDMI 2.1, which can pull off 4K processing … with dignity(?). I don’t know the full story of how the “android tv” app market stands and how it differs from “smartphone” app market, but would really want to see something “not limited to a specific vendor app store”.
Here is a separate point of contact, which is “Firmware”. From my experience, the software part of the device makes quite a difference. I had a Samsung phone and an Asus tablet, for which the question of root and custom firmware was a must from the second week of usage. And then there was OnePlus, for which it’s been 3 years since I bought it, and by this day no root and no cache cleanup’s and stuff like that (works like a charm).
Plus the matter of hardware. I’m looking for something that would actually perform (not struggle to perform in 4K, but actually perform). And in parallel, not have that “fries an egg in 2 minutes” kind of thing. I believe this is a 4GB+ DDR4+ and a decent CPU.
For the CPU itself… Can’t seem to find anything with Snapdragon (always looked at that CPU line as the “Intel” of regular PC market). Can someone tell me for which CPU’s to look after and for which not (like MediaTek)?
I do understand that an “old laptop”(if to cross out the 4K requirement), with a linux distro with some “TV based” UI on top, would be less of a hassle, but for that I have a PC, and I will be using that approach as well. But here I wanted to find something “small” for the cases, where I don’t want to have my PC running.
Thanks in advance :slight_smile:
I was looking for a good Android TV box, and every single one I found was some flavor of quad core Cortex A53, usually made by Allwiner with a few crappy exceptions that ran on dual core Cortex A7. GPU is typically very very basic.
Most advertise 4K60 h.264 and h.265 decoders so it should be fine on that front.
My main problem was no name Chinese baked OS that does who knows what while I’m not looking, and I ended up contemplating using a Galaxy Note 8 in Dex mode, as one with busted screen can be had for 30-40€. Initial setup can be done by screen mirroring and S-Pen will show cursor while hovering (I’ve done it already). It’s not Android TV OS and it’s not up to date.
I do not recommend it, it’s very clunky, I need a DeX dock and wireless keyboard with trackpad, it may blow the battery being plugged in 24/7…
But Snapdragon 835 does run circles around any quad A53 SoC.
Your best bet is the nVidia Shield TV pro despite being a bit long in the tooth if you’re not looking for a box to run LibreELEC or a similar distribution.
Yeah, that’s the thing I’m currently facing - “What the Hubert are these Rockchip, and why it sounds like a MediaTek ascendant”.
This is my second piece of headache at the moment. I remember buying Xiaomi’s clock/thermostat and after a whole hour trying to pair with the phone to configure it, I found that THAT PRODUCT is for Chinese region only and I need to choose China in the phone app’s region settings (and every time I open the app I get a ton of China’s ads).
This is what drives me in the direction of the “old laptop” idea. But it will certainly be a mess in many ways. Plus for that specific spot I am looking forward of getting a HDMI 2.1 cable for the PC (and that question has a “inconvenience” in terms of 20+ meter long cable).
And I just want something, that wouldn’t require any hassle (plus a remote out of the box).
And keeping the “Tizen” is not an option. Just not finally found the “Advent Children” in good quality on TPB with english dub as the second audio option, and it turns out that Tizen’s player developers didn’t bother with multiple audio video files…
Ah, I completely forgot about that one. Thanks.
Although I remember buying a tablet with nVidia’s Tegra. It was SAD. Really really sad. It wasn’t the first day of launch and developers had time to develop support for it, but no - it was dead and struggled to run anything.
I recommend AmLogic boards honestly. Anything that uses the 922x or the A311D CPU should be fine. Bee-link makes a few boxes using those CPUs and best of all if you wanted to Ditch Android, you can run mainline GNU/Linux on it or run LibreElec.
I actually use an Odroid N2 (not plus) as a Home Assistant hub/manager and it is the more powerful of the 922 series. Many people use these as set top boxes.
922x
311D2
*Edit
The 311D (no additional number) has a 6.0 TOPS NPU onboard for machine learning and what not.
Most do not support DRM using Android so forgot about services like Netflix etc, it might be even be blocked from Google Play Store and aftermarket support is pretty much non-existant. As much as LibreElec is nice etc you need to run CoreElec for a decent experience with Amlogic and that’s using non mainline kernel and you’re pretty much stuck with “local” media.
The Bee-link devices have official Google Play support. So you should get official DRM support for those applications.
"Install many apps thanks to being Google Play pre-installed. Used as an Android-based computer due to the fact that it comes pre-installed with everyday use software. like: browser, Facebook, YouTube, games, office apps, email, Gmail and more. "
I meant CoreElec, thanks. And I metnioned that specifically if he wanted to ditch Android and run an alternate system. OP is already running the TV in dumb mode. they may get tired of the “connected” Android experience.
Back to the topic, he asked for a setup box with Android and Android TV and I gave suggestions based on my experience. We can agree to disagree.
I can only tell you to buy the Google TV and call it a day. It pretty much plays anything for me (4k HEVC + HDR) and it has the official Android TV (obviously)! The only gripe with it I have is that the launcher is a bit laggy when starting it but after a couple of seconds it’s good
If you want a seamless and easy experience, yeah, go with the vendor’s hardware and software stack.
Thank you, good Sir.
Question to ask here - how much effort does it take to get started?
I want to start off with a “good out-of-the-box” and only then move to custom/linux if I will feel that the stock is locked out in terms of QoL I’m used to. Or even better - after 3-4 years of being a part of a custom android community, similar to XDA, playing with all sorts of Android customizations, I bought a OnePlus phone, which by this day (3 years now) doesn’t even have the root unlocked.
Honestly, I don’t use Netflix or other similarities. This is because of two reasons:
  1. In 9 of 10 cases, the things I watch (even tv series) don’t have a professional dubbed translation to my language, and even if they are, most of the time I’m better off watching it in original (it took me a few times to actually start watching “Parks and recreation”, until I went with the “Hm, what if I actually try the original audio”). Thus “I get my movies and series from non-netflix” sites.
  2. Most of the time I watch something from 90s-2000s. I don’t know if Netflix or something even has all the things I like in one service (and to pay a subscription just to watch one thing… nah, sry, USD in my country has a quite crazy exchange rate to even consider).
    2.1. As with Spotify, I do not like “streaming generic quality” of the things I watch and listen to (feels like listening to 192bpm mp3’s on Sennheiser’s HD800s).
So yeah, “local media” is what I’m aiming for.
Thought about that. But the more I look into it, the more I get the idea that it didn’t go far from my TV’s Tizen.
I can watch a movie, but I often run into codec issues (mostly sound). Not even speaking about all other quality of life things, which you get from MxPlayer (I’m currently watching a series, where at the start of every episode I need to go to settings>captions>turn off… not even gonna say how quickly it got old).
I even can open a site with an embedded video and can even watch it quite well (it recognizes an embedded video and the built-in video player kicks in rather well). But at the same time the browser is still quite rough on the edges and storing cookies (if for example, I’m watching something from a site, which stores the position of the viewed file) isn’t a thing (or even remembering the opened tabs…).
As far as I’ve read, “Google TV” is android, yes, but it has it’s sweet amount of restrictions if to compare to a regular non-root android experience.
Allwinner H6 is probably your best bet if you’re looking for best possible support (for now at least) as far as ARM SoC goes. Amlogic (CoreELEC) relies on a few ppl hacking on a fork which will never be mainlined and already quite a bit behind mainline so that might be something to consider. Intel i3 is still a solid perform but you’ll need quite recent and beefy hardware if you want to add scaling etc up to 4k (ARM SoCs can barely handle SD to 1080p using bilinear).
I find this to be disturbing as well. 4K by itself is a mouthful, and image processing with many different codes does seem to require a good gpu, and not a something, which sits next to a “mediatek #2”.
Thanks, will google it.
No need for a beefy video card, it’s all in software as far as I can tell in xbmc (or anything that uses ffmpeg). I know madvr on windows can make use of shaders but I don’t think that’s the case regarding xbmc. mpv seems to support shaders but it’s not that “couch-friendly” unless something changed recently…
The thing with “software decoding” is that it throws the task against the CPU, which isn’t suited for that kind of work. I do remember “Software Mode” in MxPlayer, and I do remember when I decided to gamble and bought the first Tegra tablet. At some point I found myself with a scenario, where my old smartphone was able to play a video, while the “big brother” with more horsepower felt like it was trying to lift a bus.
I’m now looking at my Tizen TV, realize that it should actually have decent (maybe?) hardware that meets the task of actually working with 4K videos, but at the same time I already several times raised the temperature of my chair in the bottom section looking at the messages, which resembled the fact that some common codecs are simply not supported (with a word “currently”, stated by the error message… thank you).
I’m thinking in that “Intel NUC” direction, suggested by Mastic_Warrior, and realize that it would be the best option. But I’m facing the question of 200USD + 150USD tax + 50USD delivery (I seem to be living on the Moon) for a 200USD product (and I’m pretty sure that it will enter my countries market maybe in a few years… and really start to question myself if maybe a “wake-on-lan” + a long hdmi cabel to my PC won’t be the easiest, cheapest and the most beneficial option.
I’m not sure what you’re trying to say, that hardware underpowered to perform task X Y Z doesn’t work as expected? From your story I guess you’re referring to Tegra 2 which was unsuitable for video playpack to being with. Tegra - Wikipedia
Tizen is Linux-based operating system which doesn’t say anything about performance shoehorned by Samsung into everything from Smartwatches to Refrigerators and in general it’s usually quite sluggish except for the hi-end models in Samsung TV-lineup. Most SoCs for TVs aren’t made with high processing power in mind, instead they’re relying on hardware acceleration which makes sense and other application/instruction specific parts of the SoC so they’re usually quite slow (think dual or quad core A53 at ~1GHz tops).
If you’re going for a NUC you’d need at least a relatively new i3 (or better) variant otherwise you might as well go for a 30$ H6 board (or Amlogic if you’re fine with the limiations) since it’s not going to perform much better anyway and get something better later on. The only issue I’ve run into which is niche is that H.264 10-bit isn’t supported and a quad core A53 box is too slow to decode 1080p material.
Firestick max is only one at present that has av1 hw decode support. That is in the us. Av1 is the future encoder that youtube and netflix worked on developing together. Id say the google tv is a mistake at present. It came out before android devices were required to support av1 via hw acceleration.
By the time it’s widely adopted you’ve gotten a new device anyway
