Android tablet help!
So, my little sister got a tablet for Christmas from "Santa" and has recently had all her games be deleted just out of nowhere and she's a bit upset so I try to install them again and I get an "insufficient storage" message so I proceed to look on forums and nothing helps, so I try a factory reset and still, nothing.
SPECS
Thomson MID1002
16GB
Pink (sisters BTW)
Hmm, looking for reviews for that particular device brings up a thread with a simillar issue as what you are describing: http://forums.whirlpool.net.au/archive/2212948
Unfortunatley it seems like they didn't use the highest quality components for this device :(
At least on my android phone your Google account backs up all of your apps including app data. I would restore it and see if a backup of some sorts comes up. But looking at the history of this tablet I would say your out of luck.
Thanks guys/girls it helped and we are going to return it and get her a new one, any recommended ones?
It really depends on your budget, but generally any Nexus device is a good bet.
Okay thanks I will look into it
Just make sure to read or watch reviews before you purchase a new device!
It was my parents that bought the tablet and because they're clueless they didn't do any research but i told them to this time, they are returning the tablet and i always do research before buying.
https://www.youtube.com/watch?v=hjCQ_ahTZM0
