An PC issue I never seen that seems like it gets worse
Last night I was using handbreak to compress some Blu Ray to put on my local server. This morning I went to go check the video files and noticed they were missing from the file location. I then started to look though the other folders on the same HDD drive and they were all empty. I went to go restart my PC. Windows took a little longer to load on an SSD. Once booted in Windows my S drive hard drive was missing. I went to go shutdown. Turn it all off. The Pc power button wouldn’t work. I moved it from one surge protector to another. Windows started to load but ended up just loading for a long time. Spinning. Then I turned it off since I was late to work
sounds like thanos’s pc minimizer worked
Is it possible, that you OS drive had just kicked the bucked?
Maybe no idea oh to check that though since it’s a SSD. Can you chdisk a SSD?
If you have a bootable usb drive try to install Windows and see if it recognizes the boot drive at all…
Yeah I’ll have to give that a shot when I get home. Think I have a USB with Windows on it somewhere.
