Hello fellow humans!
I got a bunch of old vinyl records sitting in the shelves from my old man, but since the old gramophone/phonogram was shot-to-shit ( The needle and the motor broke before I was even born so I’ve used the speakers for my alarm clock - they were shit anyway… ) I’ve got nowhere to play them.
Does anyone know of a good gramophone in the 300-500$ range?
I don’t know because the only manufacturer of gramophones in my country builds the most expensive gramophones in the world. That motherf*****!!
You would have to buy an amp or use powered speakers but here you go
http://audio-technica.com.au/turntables/
Thank you person!
Looks like AudioTechnica products have good reviews and they even make a decent one for 150$! Sweet!
Now I just need a pipe and a norwegian wool sweater so I can hipster properly....
Audio Technica is one of the good professional audio companies. They know their stuff. And they're Japanese so it's not some random chinese garbage.
AudioTechnica is know for their high quality pick-ups for vinyl. The last turntable and pick-up I braught was ~26 years ago.
Back when I was into HiFi before my hearing became damaged I had a sweet NAD system.
However what might be a good idea is a turntable that can hook up to your PC. That way you can record the vinyl to mp3 or Flac.
I have no idea what type of quality a turntable like this would be but it would get the job done...
Hi!
If you are from the US you should check out a brand called U-turn, they make quality yet cheap turntables handmade on the US. No bells or whistles, just the basic functions for a turntable. I'm not sure if they ship now to Europe but you can choose some of the components of the turntable, which is always nice.
Another good brand is Pro-ject, their Carbon Debut is really really great. Rega is nice, if you can buy a used Rega RP3 you got a turntable forever. Another cool option is buy used but u gotta learn the basics of turntables and what to look for. I found all the info long time ago on r/vinyl, great place to ask for questions.
Remember that half the sound comes from the receiver, a good quality receiver is the key for good sound. I can't help you on receivers tho, I don't know them pretty well but sure you can ask on r/vinyl.
