Amdgpu problems when posting (Startup) Proxmox
Hi All,
When proxmox starts up I get
[4.291598] [drm:amdgpu_init [amdgpu]] * ERROR VGACON disables amdgpu kernel
I have no Idea what the problem is
proxmox loads after seeing that and my 2 vms with passthru gpus 1 nvdia and 1 amd gpu load like they should
but when I test my install media to install proxmox from scratch I get Install proxmox screen
then when I click install I get a blank white screen which is connected to my amdgpu
I think somehow they are related, but not sure how, anyone have any ideas please?
Im worried if I had to start from scratch I wont be able to reinstall
Is this caused by the amd reset bug? if so how do I fix it, reasonably new to proxmox too
Any help would be greatful…
